Click Here
Replace SSIII Bezels
Old Sep 8, 2022 | 08:35 AM
jmcghee's Avatar
Removed the Bezels to powdercoat the wheels. How do you get them back in? Can not get those tabs to cooperate. Took a break regrouped and got um done THANKS GUYS!!!
Old Sep 8, 2022 | 08:39 AM
TRFREE's Avatar
I've had that problem, a good set of needle nose pliers will get them adjusted perfect. Just be careful not to scratch them.
Old Sep 8, 2022 | 12:51 PM
The wider outside end has tabs that go under the edge of the wheel and the narrower inside end has bent tabs to apply pressure. Install the wider end onto the wheel first, pressing the trim on fully, then lay the trim so the bent tabs on the narrow end go in and keep the pressure applied.
newmexguy
Jan 6, 2026 11:26 AM
first442
May 21, 2019 07:14 PM
scott_442
Aug 12, 2017 05:21 AM
tru-blue 442
Dec 7, 2015 12:58 PM
guy.graziano
Jul 9, 2008 11:40 AM
