Click Here
68-69 442 Cutlass SSII wheel details
Old Sep 8, 2022 | 05:49 PM
Billyaxe's Avatar
Hey guys, I’d like to know specifically for my 68 442 what the correct rims should look like. I’m aware that 68 and 69 were painted Argent grey and the rims are shallower than the 1970s rims. In 68 did they have the aluminum bezel rings, cuz some bezel opening edges I see have been painted silver. Also the trims rings I have seen have had a stepped edge and some a rounded edge. Anyone know exactly what came from the factory? Thanks —Billy
Old Sep 9, 2022 | 06:15 AM
1968 SSII wheels were 14x6, used stainless trim rings but did NOT use the five bezels around the openings. There was a silver-painted lip instead.
Old Sep 9, 2022 | 12:04 PM
Billyaxe's Avatar
Thank you very much. I just bought an original set from a 68 Hurst Olds owner
. They just need some touching up. —Billy
Old Sep 9, 2022 | 12:52 PM
rcorrigan5's Avatar
Randy C.
And I would say your trim rings look correct as well. Here are some shots of an original SSII trim ring on my niece's '68 - kind of a brushed sort of finish with the four rim clips.
Randy C.
Old Sep 9, 2022 | 12:57 PM
Randy C.
My experience with those trim rings is that one of the clips ALWAYS lines up right on top of a wheel weight.
Old Sep 9, 2022 | 01:52 PM
Billyaxe's Avatar
Thanks. I haven’t taken them off yet to clean. Now I know what to expect. Just curious - was 69 the exact same rim snd trim rings? —Billy
Old Sep 9, 2022 | 05:15 PM
hurst68olds's Avatar
1968 polished trim rings
1969 brushed trim rings & 5-bezels
Old Sep 10, 2022 | 09:13 AM
Billyaxe's Avatar
Can anyone recommend a brand of paint to touch up the argent grey rims? I want a correct match because I only need to touch up little nicks and scratch’s. Thanks. —Billy
Old Sep 10, 2022 | 10:44 AM
Billyaxe's Avatar
Oh an additional question for y’all: Im taking off my 7” wide rims to put the correct argent grey 6” rims and on the rears I found this spacer. Is the reason for it being there to push the old wider tires out away from the exhaust pipes? And should I leave them in there even for the 6 inch rims? Thanks. —Billy
Old Sep 11, 2022 | 08:09 AM
tt455's Avatar
As was suggested to me, the Seymour cast blast worked out well.
yorkman
Oct 13, 2018 08:41 AM
Thor7x
Wheels and Tires
24
Jul 30, 2013 07:37 PM
sicky olds
Wheels and Tires
Nov 29, 2010 06:10 AM
boese1978
Mar 3, 2008 07:44 AM
boese1978
Jan 2, 2008 06:19 PM
