Removed the Bezels to powdercoat the wheels. How do you get them back in? Can not get those tabs to cooperate. Took a break regrouped and got um done THANKS GUYS!!!
Reason: got um done
The wider outside end has tabs that go under the edge of the wheel and the narrower inside end has bent tabs to apply pressure. Install the wider end onto the wheel first, pressing the trim on fully, then lay the trim so the bent tabs on the narrow end go in and keep the pressure applied.
