Convertible Guide Pin
tkcutlass i have a new header bow and there is just a hole and no nut. thanks for the pic but not sure what it screws into. I removed it so long ago I forgot if there was a cage nut.
70convert:
The guide pin is mounted to the bottom of the header on the LH side. On '71-'72 A-body cars I've only ever seen one guide pin and always on the LH side; although Tim's photo seems to show the pin on the RH side - see post #4 above. Maybe it's a '70 thing (I've never owned a '70 car). The latching hooks grab onto the metal receivers mounted at the inside corners of the windshield.
Rodney
The guide pin fits into this hole on the LH side of the windshield header.
The latches hook into the bottom of these metal receivers.
Rodney
