I’m looking for a part number for the Delphi metri pak 100 terminals. They are the male/female pin terminals used on late 80s/early 90s GM cars.
Im starting on the custom dash harness for Project Olds-Camino. I am using a GM Delco radio plug to make stereo installation/removal easy. I did this on my 69, it works well.
The only hangup: the radio plug I got from the junkyards don’t have a wire for power antenna. We will need that wire. This is a old junk radio adapter plug This is the terminal I’m looking for.
I have looked thru the Mosier online catalog, I’m almost positive the terminal is called a Metri Pak 100.
Matt, the Metri Pak series are 150, 280, 480, 630, and 800. I'm guessing these are the 150 series. Terminals are available on Amazon. By the way, the 150 comes from the 1.5mm width of the blade on the male terminal.
