Recommended fluids
You will need motor oil with high zinc content. When I had my 54 I used Valvoline VR1 Racing Oil. Others will recommend other oils but it has to have high zinc content due to the flat tappet cam. You could also buy ZDDP and add to you oil to get the zinc. Use Dexron transmission fluid for the transmission and power steering.
I use Rotella T4 15W-40 in my 71. It's never caused any problems.
https://rotella.shell.com/en_us/prod...rotection.html
For fuel I would look for an ethanol free source reasonably close, unfortunately I don't have that option. Next best would be a Top Tier brand premium. Premium may not be necessary but it is advertised to have higher detergency than regular plus if the octane degrades from sitting you started out at a higher octane offsetting some of the degradation.
