Recommended fluids
Old Dec 7, 2023 | 05:29 AM
Zzotte's Avatar
Recommended fluids
Hello everyone, on a 1955 super 88 324 Engine with a 4 barrel what is the recommendation for oil, Auto trans fluid, power steering fluid and fuel, thank you very much.
Old Dec 7, 2023 | 06:47 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You will need motor oil with high zinc content. When I had my 54 I used Valvoline VR1 Racing Oil. Others will recommend other oils but it has to have high zinc content due to the flat tappet cam. You could also buy ZDDP and add to you oil to get the zinc. Use Dexron transmission fluid for the transmission and power steering.
Old Dec 7, 2023 | 08:45 AM
Zzotte's Avatar
Thank you, I will follow your advice
thanks
Old Dec 8, 2023 | 02:24 PM
tnswt's Avatar
'70 4-Speed W Machine
Use this code for $5 off if shopping the Vavoline website: NW42T9CK
Happy Motoring!
Old Dec 8, 2023 | 02:26 PM
Zzotte's Avatar
Thank you
Old Dec 8, 2023 | 02:57 PM
I use Rotella T4 15W-40 in my 71. It's never caused any problems.
https://rotella.shell.com/en_us/prod...rotection.html
Old Dec 8, 2023 | 02:59 PM
Zzotte's Avatar
Thank you
Old Dec 8, 2023 | 03:06 PM
redoldsman's Avatar
Occasionally Amazon runs a special on Valvoline VR1. I haven't checked lately..
Old Dec 8, 2023 | 03:07 PM
Zzotte's Avatar
Old Dec 8, 2023 | 05:22 PM
Sugar Bear's Avatar
For fuel I would look for an ethanol free source reasonably close, unfortunately I don't have that option. Next best would be a Top Tier brand premium. Premium may not be necessary but it is advertised to have higher detergency than regular plus if the octane degrades from sitting you started out at a higher octane offsetting some of the degradation.
Old Dec 8, 2023 | 09:03 PM
redoldsman's Avatar
I ran mid-grade 89 octane in the 54 and never had any issues.
Old Dec 9, 2023 | 04:18 AM
Zzotte's Avatar
I believe I get ethanol free gas here but is 90 it should be good, thanks
SavedbyHim
Aug 10, 2014 08:13 PM
HiCompOlds
Mar 1, 2012 04:14 AM
ekamm
Jan 19, 2010 12:56 PM
tarps3
Ninety-Eight
Oct 18, 2006 07:08 AM
