'55 super 88 trans
Old Jan 19, 2010 | 06:10 AM
ekamm's Avatar
'55 super 88 trans
Can anyone tell me how to check trans fluid level on '55 super 88 that I assume has a hydramatic? Also I read somewhere a good replacement for the original trans fluid would be Dextron III.
Old Jan 19, 2010 | 08:05 AM
citcapp's Avatar
Originally Posted by coldwar
The correct procedure has the engine running in neutral after ideally driving car, or at least cycling transmission through all of the ranges, car placed on level surface, and at operating temperature. The dip stick has clear markings for low and proper fluid level, when running and hot. Creep up to the full mark, adding a little at a time until level is attained, DO NOT OVERFILL, EVEN IF TRANS IS A "LEAKER", will malfunction if the fluid level continuously envelopes the valve body when running. Modern Dexron is fine. Best - CW
X2 what he said
Old Jan 19, 2010 | 12:39 PM
rocketraider's Avatar
Oldsdruid
Is this one of those HMT's that you have to remove a panel in the car floor to access the dipstick? That's what I read into his post...
Old Jan 19, 2010 | 12:56 PM
ekamm's Avatar
No it's in the engine bay. I asked how to check it because there is no park position on the shifter.
Vader
Jul 3, 2013 01:35 PM
1957 Super 88
Jun 1, 2013 03:21 PM
charlierogers
May 21, 2012 04:49 PM
Flye
Apr 18, 2011 04:24 PM
64Super88
May 15, 2010 07:24 AM
