455 Thermostat
Old Mar 11, 2024 | 01:03 AM
maxpowerta's Avatar
455 Thermostat
I found this thermostat in the 455 I'm building when I took it apart, But I cant say as I've ever seen one like this before, It looks like an interesting design. Were these any good? Why did they stop making them like this? It is brand new so I'm wondering if i should just reuse it cause it looks pretty well built.
Old Mar 11, 2024 | 03:37 AM
Found this doing a Google image search...
Part Number 3749085
https://www.ebay.com/itm/313980026854
Old Mar 11, 2024 | 03:54 AM
GM Oldsmobile Chassis & Parts Catalog dated November 1979
Opens @ 170°F
Old Mar 11, 2024 | 06:21 AM
That is an OEM t-stat. Far better quality than anything you can get today. Be sure to pay attention to the "front" marking when installing it.
Old Mar 11, 2024 | 11:17 PM
maxpowerta's Avatar
I figured it must be the original, I guess i will use it, Just wonder why they stopped making that design, were there problems with them?
Old Mar 12, 2024 | 03:32 AM
1Restorick's Avatar
The OEM Thermostats were manufactured by Dole. I do not believe that they were problematic in any way. And.....when the thermostat "door" is fully open you have slightly better water flow as well. I still run the original one in my 1972 Cutlass. It works perfect.
Rick
Old Mar 12, 2024 | 06:08 AM
Informative historical read RE: Dole Valve Company
Founded 1923 by Andrew Dole (Morton Grove, IL) - purchased by Eaton Corporation (1963). Dole Valve Company most likely consumed via several mergers & acquisitions over the years.
Old Mar 12, 2024 | 06:13 AM
Kewl info. I had heard of Dole Valve (more for heater control valves) but didn't know the story. Thanks.
Rick Mikulski
Feb 20, 2019 09:03 PM
Oldsmaniac
Apr 2, 2016 05:04 PM
69ishHoliday
Nov 25, 2013 04:03 PM
Bobac455
Oct 25, 2009 04:43 AM
kona-jack
Aug 27, 2009 10:28 AM
