Repair or replace - Lower rear shock mount
Old May 9, 2020 | 07:12 AM
forstatd's Avatar
I am beginning a restoration project on rear axle for my 66' 442. I want to fix or replace the broken lower shock mount on the driver side, that has been that way since 1971. It works just fine but doesn't look good, and always has bugged me. Does anybody know if this bracket can be purchased someplace... or does somebody have a bottom section that they can cut off an old axle?
Old May 9, 2020 | 08:19 AM
It looks like someone has already repaired it once. You can cut one off a donor rear end and replace it.
Old May 9, 2020 | 08:52 AM
forstatd's Avatar
Thanks.... I guess I will post a want add for a piece from a donor rear end...
Old May 9, 2020 | 01:15 PM
Looks to me like replacing that mount will be a lot more work than just fixing it properly, if you have a welder and grinder,etc. Seems you could cut off that piece that was added and get some more 3/8" (or whatever thickness it is) and weld it back in, grind it down, redrill hole, repaint and done.
GCH
Mar 29, 2020 09:51 AM
40Ragtop
Sep 30, 2019 06:36 PM
sortasane
Drivetrain/Differentials
May 8, 2016 11:28 AM
Mr Nick
Aug 5, 2015 09:04 PM
amermuscle1
Sep 24, 2011 10:53 AM
