Valve Stem Length 1964 330?
I assume you are meaning valve stem installed height. I don't have an exact answer for you on the (specific to) 1964 heads, but I just checked what appears to be a virgin head and they are at 1.760. I would equalize all of them at or near this height and shim / grind the stands accordingly to end up with about .020 to .040 lifter preload. For more valve stem height, click here: http://www.supercarsunlimited.com/in.../stem/stem.htm
Hope this helps
Hope this helps
