Valve Stem Lengths?
Old Jan 25, 2011 | 06:27 PM
defiant1's Avatar
Valve Stem Lengths?
I went to buy intake and exhaust valves. I notice the 2.00 intake valves were listed at 4.695" and the 1.564 exhaust valves were listed at 4.740".
Does the machinist take this into account? Or do I need to find a new vendor that offers the valve head size I want with equal stem lengths on both the intake and exhaust valves?
d1
Old Jan 26, 2011 | 04:46 AM
cutlassefi's Avatar
The exhaust valve will have a much heavier margin on it thereby necessitating it be longer to be level with the intake on the top.
Old Jan 27, 2011 | 06:47 AM
Warhead's Avatar
d1
You're going to want them to be close, but as Mark said earlier X2.
What is more important, is that when you get the heads back from the machine shop, they need to set within a correct range, for proper operation. Put a straight edge across the stem tips, when you pick them up. If they are more than .050" out (total, all valves) from one another at this point, then they won't run right.
Have the shop reset the stem heights, if this happens to you.
Good luck,
Jim
esisson
Jun 7, 2023 07:44 AM
aristellier
Jul 21, 2012 12:35 PM
66OldsOwner
Nov 30, 2011 02:04 PM
Redog
Jul 4, 2011 06:11 AM
Half Baked
Jan 10, 2008 08:43 PM
