Valve Stem Length 1964 330?
Old Nov 29, 2011 | 05:28 PM
66OldsOwner's Avatar
Hi,
Does anyone know the correct Valve Stem Length for the 1964 330? I know it's not 1.89". I've been searching for this spec for days.
Thanks.
Old Nov 29, 2011 | 10:55 PM
Rickman48's Avatar
If you're talking about valve spring height, an automotive machine shop should be able to help you, or a cam manufacturer's website.
Old Nov 30, 2011 | 02:04 PM
Super442s's Avatar
I assume you are meaning valve stem installed height. I don't have an exact answer for you on the (specific to) 1964 heads, but I just checked what appears to be a virgin head and they are at 1.760. I would equalize all of them at or near this height and shim / grind the stands accordingly to end up with about .020 to .040 lifter preload. For more valve stem height, click here: http://www.supercarsunlimited.com/in.../stem/stem.htm
Hope this helps
esisson
Jun 7, 2023 07:44 AM
aristellier
Jul 21, 2012 12:35 PM
Redog
Jul 4, 2011 06:11 AM
defiant1
Jan 27, 2011 06:47 AM
Half Baked
Jan 10, 2008 08:43 PM
