Info please 70 convert top motor
Old Oct 16, 2020 | 06:57 PM
sx455raidercelticfan's Avatar
Hi guys im trying 2 put my power top motor in the correct spot but I can't get the rubber ***** in the holes, is there a trick or a special way 2 do it?? I've had mine strapped down for over 10 years, thank u
Old Oct 16, 2020 | 07:22 PM
70Post's Avatar
Start with some sort of lubricant on the rubber ***** AND you may have to use a flat bladed screwdriver to gently push in around the perimeter of each rubber **** to force them down into the holes. That or use a punch to push down into each hole at the top of each **** (I'd try the screwdriver method first as too much pressure with the punch method might tear the *****)
Old Oct 17, 2020 | 02:32 PM
Texas69's Avatar
I second the use of a lubricant on the pointy end, and also pushing a punch or allen wrench into the hold at the top.
344870M
Apr 7, 2021 04:41 PM
Loaded68W34
Sep 4, 2020 07:03 PM
rummer
Aug 10, 2020 07:38 AM
jetsetw31
Apr 10, 2018 07:21 AM
joe_padavano
Nov 6, 2016 12:06 PM
