Lower Fan Shroud Hardware/Proportioning Valve wire connection
Old Jul 8, 2015 | 04:21 PM
rhett838's Avatar
68 Cutlass S Convertible
Question 1: My old fan shroud was chewed up at the bottom b/c it wasn't connected. I got a new fan shroud, but I'm having a hard time finding hardware to connect the bottom half. I bought some clips from OPGI, but I don't think that's right. There's 2 tabs at the bottom of the shroud with holes in the center of them. Is there some sort of bolt to connect it?
Here are the clips I got:
https://www.opgi.com/cutlass/1968/co...g/fans/CH4067/
Question 2: I'm rewiring my engine compartment. I got a new harness from American Autowire. Long story short I'm trying to hook up the brake light wire to the proportioning valve. I recently did a front disc brake conversion and the new proportioning valve wire connection is incompatible with the connection. I can buy a connection for $10 and splice it into the new harness. Before I do that I'm curious if the brass nipple from an original pv will screw into this new pv. I'd just rather not hack up a perfectly new harness...any suggestions? I don't have the original PV.
Thanks!
Old Jul 8, 2015 | 05:41 PM
tru-blue 442's Avatar
Old School Olds
My guess is your 'clips' should look something like this. They attach to the lower part of
your core support and the bolt should go through the shroud.
Can't help with the wiring, good luck with her though.
Old Jul 8, 2015 | 05:52 PM
rhett838's Avatar
That looks about right. Do you know a part # or know someone who sells them?
I'm working on my 68 cutlass convertible by the way.
Thanks for your help!
Old Jul 8, 2015 | 06:15 PM
Old School Olds
Try Florida auto fasteners. If no luck, I can dig around and see if I can come up with some.
Old Jul 9, 2015 | 07:38 AM
Any decent auto parts store sells those clip nuts. Check in the HELP! line.
Thanks!
If you had drum brakes before, they do NOT have a "proportioning valve". They do have a distribution block. I've never seen any connection to either that wasn't the round brass pin style electrical connector. What does the aftermarket harness have? Or what does the aftermarket prop valve have? Pictures would help here. Yes, you should be able to unscrew the electrical terminal from the old distribution block and screw it into the prop valve, IF it is the same as the factory design. The fact that the connector is different from factory makes me a little concerned, however.
oldspackrat
Oct 29, 2017 07:38 PM
shamusj
Jan 13, 2015 05:44 AM
Chris J
May 12, 2013 06:40 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
