After market tach issue
Old Nov 4, 2015 | 03:58 PM
Redbud40's Avatar
Installed after market TTT gauges. Everything worked fine for about 6 months, now with nothing done to vehicle tach gauge suddenly stopped working , stuck on zero. Signal at coil good, signal at wire to gauge ( disconnected from tach good) seems to be grounded ok when I put back together because int light works . Any suggestions or further diagnostics. Thanks
Old Nov 4, 2015 | 04:02 PM
allyolds68's Avatar
Did you fuse the tach?
Old Nov 4, 2015 | 10:35 PM
Redbud40's Avatar
Yes .. Fused the Tach however I did not check it since the signal seemed to work with a tach dwell gauge connected to the wire. I'll check to see if the fuse is blown at next look.
Old Nov 5, 2015 | 07:03 AM
Try the tach on a different car to see if the tach is the problem. I recently had the tach in my 62 go bad for no reason after almost five years of working fine.
Big John 85
Apr 4, 2009 12:52 PM
Big John 85
Mar 30, 2009 06:32 AM
tim72
Mar 25, 2009 10:28 AM
tim72
Body work
Feb 28, 2009 08:37 AM
citcapp
Jan 6, 2009 08:33 PM
