Old Gold
Old April 14th, 2010, 05:01 PM
Brockao1977's Avatar
Old Gold
Im trying to get my 72 Cultass Supreme ripping again...it was a 350 4bbl auto trans and now I have a 72 455 4bbl... and a clutch pedal set up out of a chevelle...olds manual trans flywheel/bellhousing...saginaw 4spd....and hurst super comp shifter....my questions are what is the best setup for the pilot bearing for the manual trans...do I have to cut off the tip of my trans(dont wanna do) or will something work that I dont know about?..I read that I can either use 350 mounts or 455 mounts...just dont mix them.....one other question does anyone have a rough idea how much horse a 455 4bbl rocket out of a 72 delta 88 would be? the car had single exhaust...thanks for any help
Brockao1977 is offline
Old April 14th, 2010, 07:32 PM
442_Mustang's Avatar
Use the block mounts off the 350 along with the frame buiscuits u have., Don't cut off the pilot of the trans. There's a way to drill the crank and also isn't there some kind of adapter pilot bushing I read about someone using.
442_Mustang is offline
Rowdies
February 10th, 2012 07:57 PM
boondocker
Non-Olds Engines
December 10th, 2011 06:06 AM
theoldsrocket
Paint
February 4th, 2011 02:52 PM
Biothree
June 30th, 2010 09:00 AM
RAMBOW
March 14th, 2010 07:44 AM
Quick Reply: Old Gold
