55Olds - Poor running can you help?
Old May 13, 2010 | 10:42 AM
55jes's Avatar
Can anyone help?!!! I have a 1955 Olds, Super 88 running stock motor and carb. I cannot get her to run on slow idle. I have already rebuilt several (!) carbs to the shop manual spec, adjusted timing etc. The engine will run on fast idle but dies as soon as the choke opens. . . Is there anything I'm missing. Please advise a frustrated Olds owner!
Old May 13, 2010 | 12:58 PM
Oldsguy's Avatar
Past Administrator
I moved your thread for better exposure, some members may not review the newbie forum. You said "rebuilt several cabs" so I am assuming it behaves the same with DIFFERENT carburetors. If so, either both carburetors are bad, or adjusted wrong (perhaps incorrect information on the choke setting or idle setting), or there is something else wrong not related to the carburetor at all. Maybe a vacuum leak? How much vacuum are you pulling on fast/cold idle?
Old May 13, 2010 | 01:33 PM
salvaged88's Avatar
Clueless Mechanic
That's where I was going check the vacuum Lines better late to the party then never getting there
Old May 13, 2010 | 03:15 PM
55jes's Avatar
Hi and thanks for the tip. I dont know what vacuum I'm getting as I hav'nt checked that yet but I will certainly give it a try.
Any suggestions on what sort of reading I should get and should I attach a gauge to the carb base where the distributor vacuum advance connects?
I'm assuming that it wont have anything to do with the vacuum side of the fuel pump?
What could be the cause of a vacuum leak please?
Old May 13, 2010 | 03:28 PM
lshlsh2's Avatar
71 cutlass convertible
My guess is most vacuum leaks are from old cracked lines.
Larry
Old May 13, 2010 | 08:36 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have found over the years a vacuum gauge is one of the best things you can have for one of these old cars. I think you should probably be pulling about 15-20 inches of vacuum. I would start by capping off everything at the carb and manifold. It could be windshield wipers, vacuum advance on the distributor. Then it could also be a leaking base gasket on the carb but I assume that is new since you have rebuilt the carb. Intake manifold gaskets could be another problem. With the engine running, you can squirt some WD-40 on where the manifold meets the heads and it should smooth out temporarily.
Carl, uk
Mar 13, 2014 05:43 AM
at3reg98
Nov 18, 2012 02:21 PM
patmills
Brakes/Hydraulic Systems
Aug 15, 2010 07:15 PM
Shebe72
Jul 5, 2010 08:11 AM
DAN76
Jul 28, 2009 02:13 AM
