Water Pump
Old Sep 16, 2010 | 05:49 PM
TripDeuces's Avatar
Water Pump
I'm looking for an Olds water pump that is 5.25 inches from fan mounting flange to timing cover. I've been told this is the 'short version'. I can't find this dimension pump anywhere, all are longer. Is my info wrong or what am I missing?
Old Sep 16, 2010 | 05:51 PM
f-85's Avatar
there is 3 versions. 5.1, 5.6, and 6" pumps. I have 2 5.1s but i dont know if they work. (originals off of 425s) I can tell you that both where off 1965 425s 1 88 and 1 98. ill look it up on autozone. BRB
Old Sep 16, 2010 | 05:54 PM
TripDeuces's Avatar
Well that's a start. I can work with the 5.1.
Old Sep 16, 2010 | 05:55 PM
f-85's Avatar
Yep autozone has them too. 1965 olds 88 425 2bl non A/C. http://www.autozone.com/autozone/par.../N-ixzryZ9pd8f
The other motor i have was out of a 1965 98 425 4bl with A/C this is 5.1
I forgot i had to swap mine out of my 64 once. I used a 65 cutlass 330 with A/C. That one is 5.1 too. so try any one of those and you should be good
Old Sep 16, 2010 | 05:57 PM
TripDeuces's Avatar
Fantastic! Thanks F-85
Old Sep 16, 2010 | 05:58 PM
f-85's Avatar
no problem
Old Sep 16, 2010 | 09:09 PM
Run to Rund's Avatar
Carquest rebuilt 5.125" height water pump (for 66-7 all non AC) is 10.1002. The AC pump is same height, different number.
Nor Cal Andy
Mar 29, 2012 07:27 PM
72Ctlss
Jun 23, 2009 03:12 PM
greener_dude
Feb 18, 2007 08:14 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
