Aftermarket Rad and Electric Fans
Old Nov 26, 2010 | 07:12 AM
Axeni's Avatar
Hello.
I have a 71 455 out of a 88 in my 69 cutlass rag (stock as far as I have been told).
I have a non clutch fan that is high performance and it is so loud that I dont even hear the motor or exhaust when I am over 2k rpm. I would like to get rid of that fan and replace it with electric fans. Has anyone on these forums done so? I have found some on Ebay very inexpensive. I worry about the old
"you get what you pay for"
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWAX:IT
Has anyone done this without fear of overheating.
(my apologies if this in the wrong spot.)
________
HotStella
Old Nov 26, 2010 | 07:29 AM
bigoldscruiser's Avatar
2 '66 98's
You can use a dual fan setup from a 98-04 Dodge Intrepid, Chrysler Concorde or 300.
It makes a very nice fit, is two speed. Set one speed to operate from temp control and the second to come on with A/C if you have it. If no A/C, the second speed can be hooked to a manual switch for extra cooling in heavy traffic. They are fairly plentiful in bone yards or you can buy a new replacement set on line for a reasonable price. JEGS has the control packages.
Old Nov 26, 2010 | 07:57 AM
Axeni's Avatar
That sounds pretty good actually. Would that setup be using the stock rad>
Thanks BigOl
________
Web Shows
Old Nov 26, 2010 | 09:51 PM
2 '66 98's
I am using the standard 3-core replacement rad due to the A/C and a fuel injection set-up on my 425ci which requires a 195 degree thermostat. It runs up to about 210 degrees in standing traffic.
68conv455
Mar 12, 2013 06:32 PM
1971 442 convert
Oct 23, 2012 07:50 AM
Wyze
Sep 10, 2010 01:07 PM
chris83
Jun 13, 2009 08:16 PM
oldjunk
May 1, 2009 03:10 AM
