Antenna
Old May 4, 2014 | 07:05 PM
Bfg's Avatar
Bfg
Antenna
I'm removing the pass. Side fender but can't remove the antenna base because of the corrosion. Anybody have any solutions?
Old May 4, 2014 | 07:18 PM
Octania's Avatar
Break it off?
What year/ model?
Penetrating lube and HEAT are the time-honored favorites.
Sometimes you have to sacrifice one part to save the other.
Old May 4, 2014 | 07:40 PM
Bfg's Avatar
Bfg
1965 cutlass, hate to break the antenna housing. I'm letting it soak with penetrating lube. heat will melt the rubber gasket.
Old May 5, 2014 | 09:23 AM
Octania's Avatar
TOO MUCH heat will harm the rubber and etc.
Use less heat.
Think hair dryer or heat gun held back a bit.
Penetrating lube, then wiggle back and forth with a LOT of patience.
Do you have the perfect correct tool for gripping the thing you need to remove- pin wrench or whatnot?
curtis mayfield
Feb 21, 2023 07:13 AM
64Todd
Dec 18, 2008 07:43 AM
oldssragtop
Dec 26, 2006 08:22 PM
awspeich
Nov 5, 2006 04:33 PM
JoshF85
May 25, 2005 08:14 PM
