1964 Cutlass Antenna
Old Jun 12, 2007 | 05:04 PM
64Todd's Avatar
Anyone know how to get at the antenna on the passenger front fender? Mine needs replacing....
Will removing the cowl do the trick? Or will the fender need to come off?
Old Dec 11, 2008 | 01:27 PM
MarkR's Avatar
Did you ever figure it out? I have same question on '66 Cutlass
Old Dec 11, 2008 | 04:05 PM
You should be able to unscrew the bezel on the outside of the fender, allowing the body of the antenna to be pulled out from the underside of the fender.
Old Dec 12, 2008 | 09:15 AM
rocwal
Guest
Posts: n/a
63 64 cutlass antenna
I stripped out some 63 64 buicks last year and there is a panel under the wheel well has to come off ,to access the hold down for lower part of antenna ,once top and lower are unfastened it pulled out the hole in fender well . Not sure if cutlass is the same .
roc wal
Dan B
Old Dec 18, 2008 | 07:43 AM
65cutty's Avatar
I had to unbolt the bottom mount and pull out the fender to reomve mine, the little screw on the brkt isnt fun but that way saves scratching anything.
curtis mayfield
Feb 21, 2023 07:13 AM
CRH
Jan 30, 2018 09:27 PM
64oldsf85cutlass
Body work
Jul 4, 2014 07:06 AM
scr8p
Jul 13, 2011 08:38 PM
rroth01
Feb 21, 2011 07:53 PM
