69 olds antenna
Old Dec 24, 2006 | 09:20 AM
oldssragtop's Avatar
69 olds antenna
How hard is it to take out and replace a antenna on a 69 cutlass??. tim
Old Dec 26, 2006 | 09:01 AM
Oldsguy's Avatar
Past Administrator
You must have very small hands and be a contortionist. Actually, I think if you remove the inner fender well you can reach up and access the bottom of the antenna assembly. If you have plastic inner fenders it is easy, just remove the nuts on the perimeter of the fender lip and bend it out of the way so you can reach up with your arm. Then it is a simple act of backing the nut off on the top and dropping the assembly down, the coaxial to the radio runs through a hole in the body, I think forward of the door seal area, there may or may not be a rubber gromet there, if you disconnect the coax, tape a line to the end so you can pull the replacement coax back through, unless you are removing the antenna for good. Hope this helps.
Old Dec 26, 2006 | 08:22 PM
69oldsguy's Avatar
I have had luck opening the pass door and going at it that way. I have done complete changes without removing anything but the pass kick panel. Yes, you still need small hands and be flexible as Oldsguy says, but it can be done without pulling the inner fender. Enjoy those tight spaces. I have to do a speedo cable.
Kevin
curtis mayfield
Feb 21, 2023 07:13 AM
oldsladyliz
Ninety-Eight
Aug 20, 2013 02:45 PM
67delmont330
Nov 18, 2011 01:40 PM
PalmSpringsOlds
Aug 27, 2010 09:52 AM
johnras@wavecable.com
Mar 11, 2008 04:59 PM
