Rocket Racing Valve covers
I have a set of tall valve covers and am now discovering they wont allow the drivers side alt brackets to fit or the a/c brackets. I would like to run the original brackets with minimal modifications. Is anyone out there using these covers with stock bracketry of some sort? If not are there any companies making olds setups?
I never cease to be amazed that people are surprised by this. The stock brackets wrap tightly around the stock valve covers. What did you think was going to happen when you changed to taller valve covers? And no, there are no companies who make brackets for the 20 or so Olds owners who want to run tall valve covers and A/C.
Dear Joe, with all due respect, you have to understand that not everybody is as knowledgable as you.
People make mistakes, especially if this is his first time around a olds engine.
What is the purpose of this forum if people can't ask questions, no matter what they are?
I think we need to encourage people to ask questions and stay in this hobby and not discourage them by answering in such manner.
JMO
JMO
JMO
JMO
I am 49 yrs old and have owned more oldsmobiles than I can count, done countless stock motors and restorations, it is not my first time around one of these engines but had no previous experience with Rocket Racing valve covers. I realize the top bracket is very tight on the left side and was going to make something else work but was trying to use the front part. It looks like the a/c will not work at all with stock brackets anyway but I just threw it out there to see if anyone had worked around some of it so it could look as close to stock as possible. I usually appreciate what Joe has to say as insightful and experienced but in this case you could have saved the snide comments seeing as your supposed to be some kind of someone on this site. Thanks for no help and I guess I'll think twice about contributing at all here in the future. Thanks again Joe. By the way there is a company making a set-up for the 20 or so olds guys that want to run tall valve covers and A/C. -March pulleys- makes an awsome set of brackets and pulleys that I'll be using that place things a little forward of the valve covers though not at all stock but they look awesome.
Truly the modifications required to the brackets to clear taller valve covers is not that tough access to a welder a 4" grinder with a cutting wheel, couple hours labor and done. Also have to use longer fan belts but easy peasy as they say. have done two of these with edelbrock heads and still easy and looks stock to the unknowing eye.
Personally if I wanted tall valve covers with A/C, I'd adapt the 307 brackets for about $20 and have plenty of clearance for the tall valve covers. These brackets use the short R4 A/C compressor, which is also lighter, and mount the accessories far enough forward to clear the covers.
RAMBOW
March 20th, 2017 06:58 PM
Ctott70
December 16th, 2010 06:12 PM
