horn is staying on
Old Jul 6, 2014 | 03:00 PM
joscas's Avatar
horn is staying on
I have a 1970 442 with tilt steering, I just change the steering wheel and everything when smooth till I connected the battery and the horn is staying on, took the steering out 3 time but I don't see what I'm doing wrong....can anyone help
Thanks,
JC
Old Jul 6, 2014 | 03:08 PM
RandyS's Avatar
When a horn sounds, that means it is being grounded. Did you put the spring in place under the cap? Is there a wire pinched somewhere and touching metal?
Old Jul 6, 2014 | 03:27 PM
As stated above, either the wire is shorted to ground or its assembled incorrectly.
Old Jul 6, 2014 | 03:47 PM
joscas's Avatar
The spring is under the plastic cap, but I'm not sure if the connector clip was touching other metal besides the cap that connect above the steering wheel...I'm new at this....I will try again later....Thanks for info.
JC
DennisG.
Apr 15, 2012 11:01 AM
deltathunder
Aug 2, 2010 12:06 PM
kevin442
Apr 27, 2009 03:07 PM
Jolly Green
Mar 15, 2009 06:21 PM
jk121
Jun 13, 2007 12:35 PM
