'67 olds cutlass supreme
Old Jun 18, 2014 | 10:37 AM
frbiejr's Avatar
Are the heads on a 330 ci high compression engine interchangeable from left to right & right to left? Just purchased car and owner said the heads were switched. Numbers stamped on head are now on left side at the rear of engine instead of front right. Runs hot & I wonder if this is related.
Thank you,
Frank
Old Jun 18, 2014 | 10:50 AM
Oldsmaniac's Avatar
No effect at all... fine
Old Jun 18, 2014 | 11:35 AM
Thank you,
Frank
All Olds V8 motors (except for the Aurora) use the same head on both sides. Your overheating is caused by something else.
Oldssupreme
Apr 3, 2015 08:36 PM
70olds455
Sep 11, 2011 03:52 AM
travisbeamon
Aug 7, 2011 12:51 PM
olds70supreme
Aug 1, 2011 05:22 PM
1967delta
May 1, 2010 06:16 PM
