Lower Control Arm vs Down Pipes
I took a photo of my starter in order to give me some ideas for a heat shield, and noticed that the lower control arm is rubbing against the down pipe. This is after 5,000 miles. When the pipe was put on it was crimped a bit to clear, but obviously not enough.
Eventually I will have to deal with this because that spot is going to rust through.
I keep on finding funky things with these reproduction control arms.
Here is an update. It turns our it is not the LCA that is rubbing on the exhaust pipe, but rather the frame support for the LCA bushing mount. This probably occurred during installation, and there is no sign of recent contact, so I just put some rust converter on and them painted with high temp paint.
oldzy
Dec 19, 2011 06:43 AM
