small block down pipes.
Old May 22, 2014 | 09:19 AM
s i 442's Avatar
Oldsmobile enthusiast
Will the "Pypes" down pipes fit a 71 Cutlass Supreme with a 350 and stock manifolds that already have the cross over pipe blocked?
I really just want to do the project myself at home verses taking off work to get it done. Thank you.
Old May 22, 2014 | 08:25 PM
68442's Avatar
Yes they will work. I have their down pipes and rest of their system on my 72 Supreme 350.
BTW i have the street pro mufflers and they are terrible. They both have something inside them rattling/vibrating.
The system in terms of fitment fit great.
Old May 23, 2014 | 09:17 AM
s i 442's Avatar
I just want to use these pipes and whatever it takes to get a pair of Thrush Welded mufflers to the rear end and dump.
Old May 23, 2014 | 10:30 AM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
Can you give me the Pypes part# to look up those pipes, it's not in the image filename.
Thanks!
Ed:
Ah, DOF10S.
Old May 23, 2014 | 03:16 PM
s i 442's Avatar
SUMMIT: PYE-DOF10S $109.97
PYPES sites: DOF10S $135.45
Old May 23, 2014 | 06:48 PM
johnnyjaws's Avatar
it says 442 not 350 are they the same
Old May 23, 2014 | 07:30 PM
s i 442's Avatar
The guy up above says he put them on a 72 with a 350???? Any adjusting or??? We may never know, people like to keep others in the dark about important things but will give a 35 min speech about oil and filters!
Im going to buy the pipes and do the project and at least I will know if they fit or not.
Old May 24, 2014 | 04:50 AM
68442's Avatar
Sorry my mistake i should not have responded at all. Your going to dump on the only guy who responded to you with any pertinant info at all this is why guys don't bother with putting anything out there to help
If you read the text i said the fitment was great. If there were any concerns i would have said as such. Did i not mention issues with their mufflers if you are choosing to use them?
Old May 24, 2014 | 06:54 AM
holiday88's Avatar
Are there any leaking issues with the two inch manifold opening going into a 2.5" pipe?
Old May 24, 2014 | 07:46 AM
^^^This!
One thing to keep in mind is that Olds designed the outlet ports on the A-body manifolds to be in about the same place for both BBO and SBO applications. That's why the pipes fit a small block also.
Old May 24, 2014 | 12:41 PM
68442's Avatar
How they are made is they start with a Stock size pipe flare(2" or 2 1/4"?) whatever it is, then immediatly, within 2" or so, blow up to the 2 1/2" pipe.
Old May 24, 2014 | 01:09 PM
Nop's Avatar
Nop
May I ask how far back they reach?
From the pic they don't look as if they are long enough to reach the mufflers, are they?
Old May 24, 2014 | 01:35 PM
68442's Avatar
They go back to the crossmember only. These are made to fit aftermarket exhaust systems to stock manifolds, weather it be Pypes or Flowmaster Etc. These would take up the space of headers.
These are down pipes Not Head pipes
Old May 24, 2014 | 01:53 PM
Nop's Avatar
Nop
Yes, I'm aware that they're not headers.
I'm thinking about replacing most/all my exhaust and my glasspacks with new pipes and Dynomax Turbo mufflers, those Pypes pipes look like a good start.
bocoogto
Aug 26, 2023 06:09 PM
pcard
Apr 30, 2014 05:07 PM
kitfoxdave
Oct 8, 2013 08:52 AM
olds4life
Feb 9, 2010 08:48 AM
citcapp
Jan 31, 2009 04:01 PM
