Hard shifting
Old May 10, 2013 | 01:46 PM
pcard's Avatar
70 Cutlass SX
Hard shifting
I took the car out this morning to fine tune the timing and on one hard acceleration the transmission did a pretty hard up shift at about 40 mph. There was a sharp metallic clang from the transmission.
The car drove fine afterwards, but I only took it a few hundred yards.
Should I be concerned? Is there something benign that would cause this?
Old May 11, 2013 | 02:10 PM
pcard's Avatar
70 Cutlass SX
Any thoughts on this? Anything I should check out next time I back in the US?
Old May 11, 2013 | 02:20 PM
coppercutlass's Avatar
Chevy budget Olds powered
how long did it sit the clank may have been the drive shaft or possible loose trans mount which you would be amazed how easy they get loose. And the trans hard shifting could have been a pressure problem where something was gunked up and got free up after so much pressure.
Old May 11, 2013 | 03:59 PM
pcard's Avatar
70 Cutlass SX
Not long, and I had just returned from a 20 mile cruise, so I think things were fairly well warmed up.
Old May 11, 2013 | 04:11 PM
if something gave out. The first sign would be in the trans pan. if you suspect internal damage drop the pan and inspect.
Old May 11, 2013 | 04:39 PM
pcard's Avatar
70 Cutlass SX
OK - will do that in June when I get back.
Thanks.
allyolds68
Aug 22, 2012 06:34 PM
al714
Nov 29, 2011 06:14 PM
cjprm
May 19, 2011 09:17 AM
nohn
Jul 22, 2007 10:57 AM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
