how to adjust rockers and push rods on a 350?
Old Apr 18, 2013 | 02:31 PM
stavo71's Avatar
so do i just tighten the bolt down? rockers dont seem to be adjustable .
Old Apr 18, 2013 | 02:34 PM
Oldsmaniac's Avatar
They are not adjustable. If making noise they are likely worn. They need to be replaced in sets of 2.
Rickman48's Avatar
That's it - you're done!
Old Apr 18, 2013 | 02:38 PM
coppercutlass's Avatar
Chevy budget Olds powered
I thought shimming could be done for adjustment if needed.
Old Apr 18, 2013 | 03:19 PM
stavo71's Avatar
ohh ok i figured . just wanted to make sure before i went ahead and did it.
Old Apr 19, 2013 | 07:50 AM
If the parts are worn and ticking, it's hard to install a negative thickness shim.
Old Apr 19, 2013 | 08:11 AM
I probably should have been more specific. I was just saying if adjustments needed to be done couldn't it be shimmed. I did not say that to aid the issue. If they are worn replace them. Now for instance say you rebuild the engine and everything is good and you have new rockers. They could be adjusted by shimming if needed right ?That's all I was getting at.
Old Apr 19, 2013 | 08:33 AM
And again, maybe yes, maybe no. Shimming can only adjust in one direction - away from the head. If you need to go the other way (if you have a reduced base circle cam, for example), you cannot get a negative thickness shim.
Old Apr 19, 2013 | 09:05 AM
Rickman48's Avatar
If you've 'ticking' after replacing rockers and stands, If the pushrods are good, you may have a broken valve spring, and/or cam going flat, taking out the lifters as well.
Even adjustable aftermarket rocker arms won't help that!
rktolds
Dec 15, 2014 11:04 AM
bosch 68 442
Jun 29, 2011 05:02 PM
65cutty
Sep 8, 2010 02:22 AM
Atdog
Feb 14, 2009 06:51 AM
Pinner
May 31, 2007 12:26 PM
