Crank Case Ventilation
Old Jan 29, 2013 | 08:03 AM
boese1978's Avatar
Rebuilding my '68 350 and want to get some nicer valve covers. Found a set with no holes and or grommets. Can I use them without punching a hole for the PCV valve? Any alternatives to ventilating through the cover?
Old Jan 29, 2013 | 09:00 AM
Sure. Do like the 70-72 W-30s and put the PCV valve in the valley between the runners of the intake.
Old Jan 29, 2013 | 09:11 AM
Octania's Avatar
Better be a place for the air to COME IN also. Not right next to the exit, preferably. Also, the fumes flow the other way at times, so that air entry should connect to the air filter housing.
This may not be the ideal candidate for a system to abandon to "tidy up the engine compartment."
Old Jan 29, 2013 | 09:14 AM
1970-W30's Avatar
It's still going to need at least one of the valve covers punched out for a needed breather, or maybe the oil fill cap has to be changed to a ventilated breather style If possible, if you do not want to punch out a valve cover. I don't believe just running a PCV valve alone will work, there has to be a way to introduce air in for the PCV valve to pull, or the setup will create a high vacuum in the engine and suck oil and/or oil vapors into the engine. The W-30's actually used two breathers plus the PCV valve setup in the manifold like Joe mentioned.
(I see Octania beat me to it)
Old Jan 29, 2013 | 09:21 AM
You are both correct, you would want a breather cap on the oil fill tube, a la the 1967-earlier cars.
Old Jan 29, 2013 | 10:57 AM
1970-W30's Avatar
While we're kinda of on the subject of PCV valves, does the W-30 PCV in the intake have any type of baffle under it, or is it a "dead" area that does not have much in the way of oil and/or oil vapors that could be sucked up.
Old Jan 29, 2013 | 12:31 PM
van Dyck's Avatar
Should definitely have a baffle on the vacuum side. The motion of valve lifters can toss oil in a variety of directions.
chasman414
Oct 4, 2012 03:21 PM
68Tom
Nov 8, 2010 02:14 PM
jensenracing77
Sep 4, 2009 05:39 PM
Snowdog
Apr 11, 2009 11:43 AM
iuhoops83
Aug 2, 2007 11:22 AM
