Upper cowl chrome trim screws
Old Feb 4, 2013 | 11:50 AM
jjokrm's Avatar
I'm going to repaint the cowl under the windshield on my 68' cutlass and need to remove the lower windshield chrome trim piece (right above the top of the cowl). The screws for this (all 7 or 8 of them) are so rusted that they are seized and I've already tried PB blaster, but no luck. I'm going to have to drill them out so I needed to know if anyone knows the size of these screws so I can go purchase some nice stainless ones at the hardware store. I'm afraid that after drilling them out, I won't get a decent one to use as reference for thread size. Any help would be awesome!
Old Feb 4, 2013 | 12:22 PM
The cowl trim is actually stainless steel - as is the rest of the windshield reveal trim. The screws you're talking about are available aftermarket. In Line Tube has them
Pn# - INL10602 -14pc $12.00 Set
If you drill them out use the smallest bit you can to avoid enlarging the holes.
Old Feb 4, 2013 | 12:26 PM
jjokrm's Avatar
Good deal. Yes, I planned on using the smallest bit to get those bad boys out. Thanks!
Old Feb 4, 2013 | 12:28 PM
I hate to say this, but be prepared to find rust holes under the stainless.
Old Feb 4, 2013 | 12:31 PM
Very likely, but you never know till it's off. Could be isolated to just a few.
Old Feb 4, 2013 | 12:35 PM
droptopron's Avatar
delete
70Post (Patton Glade) got these for me. I bet he can give them to you for a break over what the other vendors charge.
Old Feb 4, 2013 | 12:38 PM
jjokrm's Avatar
Thanks for the heads-up. What did he charge you?
Old Feb 4, 2013 | 12:39 PM
jjokrm's Avatar
Yea, I'm afraid of this. We'll see.....
Old Feb 4, 2013 | 12:41 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Used correctly heat can be your friend here. Heat with propane or butane. Don’t get it hot enough to discolor the metal or warp it. About 5-10 seconds followed by a cold water quench. Do this a few times. You can use heat putty or encircle the screw with wet rag to prevent the heat from walking around. Its all in the technique. Try to find one of those small butane mini torches. They work well for this vs a standard plumbers propane/mapp bernzomatic style.
Then insert a screwdriver into the screw head and gently tap with a small ballpeen hammer. Repeat as needed until they give up. The above method used with patience and PB-Blaster or Kroil should break them loose.
Old Feb 4, 2013 | 12:43 PM
Depending on how much rust, you can still fabricate new metal in there and drill the proper holes for the screws. Don't be discouraged by the thought of rust - just be prepared for it. On a 44 year old car rust is just inevitable. Hopefully it hasn't been stored under a tarp for the last 5 years....How does the rest of the body look? You can likely gage the 'damage' under the cowl trim by the overall condition of known rust areas on these cars.
Old Feb 4, 2013 | 12:55 PM
jjokrm's Avatar
I do have a small butane torch, so I might go this route before drilling. Thanks for the instructions and help. I really appreciate it.
Old Feb 4, 2013 | 12:59 PM
jjokrm's Avatar
The car is in great shape...7 out of 10 I'd say. I do know of a few spots of body filler though and the top passenger side of the cowl has been patched as well. My current plan is to completely clean, patch if necessary and rust proof the cowl, including the inside of it. I know you can purchase the whole upper cowl for around $350, but too much of a pain at this point to replace the whole thing. I'll see exactly what I get into once I get stuff apart. Thanks again!
Old Feb 4, 2013 | 04:57 PM
Boldsmobile's Avatar
Try making a slot with a cutoff wheel and than use an exact matching flat screw driver.
Old Feb 4, 2013 | 06:21 PM
junior supercar's Avatar
yep, I used this method with a dremel many times and the flat blade screwdriver takes the screws out. no damage to the holes and you still have the screw, albeit with a slot in a now.
Old Feb 6, 2013 | 04:39 AM
jjokrm's Avatar
I may try this method as well.
Thanks to all you guys for the great and very helpful advise. You've made my job easier. Now all I have to do is find the time to make it to the garage to work on the thing!
RandyS
Jul 13, 2015 04:48 PM
markmets415
May 24, 2013 02:00 PM
bluefire
May 13, 2013 05:14 AM
HonestDave
Nov 1, 2012 01:10 PM
Alex72cutty
Feb 7, 2012 07:32 PM
