Series
Old Dec 28, 2012 | 05:05 PM
jankyrre's Avatar
Question Series
Probably a stupid question.
The service Manual is referring to series,but what serie is a -68 442?
Old Dec 28, 2012 | 05:24 PM
The Cutlass/442/F-85/Vista Cruiser are all A-body or A-series cars in that year.
For more info on GM car lines:
https://classicoldsmobile.com/forums...platforms.html
Old Dec 28, 2012 | 06:30 PM
jankyrre's Avatar
If a drawing in the manual referees to series 31 thru 48,and another one to 54 thru 86,which one is for a -68 442?
Old Dec 28, 2012 | 06:32 PM
44
Old Dec 28, 2012 | 06:37 PM
jankyrre's Avatar
Thank you.
Old Dec 29, 2012 | 06:03 AM
Ah, now I understand the question. Turn to the chart in the front section of the Chassis Service Manual that lists the various model designations. You'll see that the second and third characters of the VIN are the series designation for your model. As Allen noted, 44 is the series designation for a 1968 442. 48 would be a Vista Cruiser, 42 a Cutlass Supreme, etc. Collectively, all 31-48 series are A-body cars. Note that these model and series designations changed from year-to-year. To further complicate this, starting in the 1972 model year, Fisher Body continued to use the two digit series designators on the cowl plate but the VIN only used a single letter. And as you may have already found out, on the 1968-69 442s, many if not most had a cowl plate that showed a 36 series even though the VIN correctly showed 44. This is well documented in the factory literature.
Redog
Feb 9, 2009 01:13 PM
Allan R
Sep 13, 2008 09:22 PM
michaelallen747
Aug 18, 2008 05:14 PM
rocketmann
Jan 6, 2008 07:55 PM
