Best Valve Cover Gasket
Old Dec 3, 2012 | 07:23 PM
Mr Nick's Avatar
What is the absolute best valve cover gasket to use? Specifically with cast aluminum covers, if that matters.
I believe the SCE's have crush sleeves to prevent over tightening.
http://www.summitracing.com/parts/sc...ake/oldsmobile
Edelbrocks have a steel core
http://www.summitracing.com/parts/ed...ake/oldsmobile
Mr Gasket seems similar to Edelbrock
http://www.summitracing.com/parts/mr...ake/oldsmobile
There is also the plastic kind that has 2 rubber seals, almost like O rings that go all the way around. Didn't see them on Summits website.
Old Dec 4, 2012 | 01:55 PM
don71's Avatar
same but different
Nick, unfortunatly the best gasket IMHO is not being made anymore.
Formally known as the "Felpro perma dry plus" part # VS 13403 T.
Maybe you'll have luck finding some old stock...good luck. If I had to choose from your examples, I'd pick the SCE, but I haven't used them.
Old Dec 4, 2012 | 03:12 PM
I've found just plain old cork or rubber work fine with olds engines. Make sure the surfaces are clean and reassemble.
Old Dec 4, 2012 | 03:54 PM
Mr Nick's Avatar
Don - that is the one I was referring to but didn't see on the website. I used to have a set laying around, time to check storage!
Old Dec 4, 2012 | 06:09 PM
72w442's Avatar
72 442 Conv Viking Blue
I have these as well, best valve cover gasket I have ever used. They have been on and off about 6 times in the last 8 years and never a leak,sorry to hear they are no longer made.
Old Dec 13, 2012 | 12:31 PM
jfb's Avatar
jfb
I have had a set of basically harder plastic valve cover gaskets that have been re used several times with no problems. I recieved these from mondello performance and have had no problems for almost 10 years, By the way check your local speed shop also for a set if you are interested in them. these gaskets avoid the bs that others can have.
Old Dec 16, 2012 | 08:00 AM
Mr Nick's Avatar
Don, I found my old set of those valve cover gaskets. The cast Oldsmobile covers I bought came in this week as well. Looking forward to a 'new' slick set of covers with NO LEAKS.
Will be replacing a set of stock appearing tall covers.
Old Dec 16, 2012 | 08:51 AM
Rickman48's Avatar
I use cork, and weatherstrip adhesive to the cover.
Never a problem, if you grease the head
Bobac455
Dec 4, 2013 09:23 AM
harry k
Nov 21, 2012 08:54 AM
Ddbord
Aug 12, 2010 01:17 PM
dallasite21
Jun 20, 2010 05:37 AM
and1stp
Sep 26, 2006 04:43 PM
