Differential capacity
Old Jun 24, 2012 | 07:01 AM
boese1978's Avatar
I added a repro finned aluminum cover with "additional capacity" but I do not know how much. Is it like my outboard where I fill until it comes out the top (fill hole in this case) hole? I know the book says 2 pints for the stock cover.....
Thanks!
Old Jun 25, 2012 | 02:06 PM
Mikes65's Avatar
That is the way I have always done mine. I believe it is the correct procedure. The car must be level.
Old Jun 25, 2012 | 02:19 PM
It actually should be 1/2" below. I usually stick my finger in the hole and if I can touch fluid at the first knuckle, it's full.
Old Jun 25, 2012 | 03:02 PM
Eddie Hansen's Avatar
a question regarding posi..
I also added a cover with extra capacity I have a posi rear do I need to add more additive? I mean more fluid means it dilutes the additive right? Anyone know?
Old Jun 25, 2012 | 03:37 PM
How much extra capacity? I don't think it's going to make a lot of difference as far as additive goes.
Old Jun 25, 2012 | 03:50 PM
ELY442's Avatar
I agree with Oldcutlass. I just add enough oil until it touches my fingertip. When the oil gets hot, it expands. You do not want to overfill the rear end.
No, you do not have to add another bottle of posi additive from what i've been told from a guy who rebuilds drivetrain for a living. He told me you will do more harm than good.
Old Jun 25, 2012 | 04:19 PM
As long as its not binding up your fine!
1arunem
Feb 13, 2009 06:50 PM
scrappie
Apr 3, 2008 06:41 PM
phantom.10
Sep 28, 2007 04:47 AM
Pete77
Drivetrain/Differentials
Jul 22, 2006 12:12 AM
Pete77
May 15, 2006 05:37 PM
