Silver Zinc Plated Rotors?
Old Feb 6, 2012 | 11:43 AM
ent72olds's Avatar
Registered Luser
I've seen these also...obviously good against surface rust. I also read that another company claims the plated brake rotors are bad on the bearings! Is there any truth to this? Should I be buying Zinc plated or raw? Thanks...
Old Feb 6, 2012 | 03:20 PM
Bluevista's Avatar
Registered
I read once where this guy thought that because the brake pad contact surface rusts on his zinc plated rotors after a few weeks of sitting outside that it means the plating doesn't work.
Wouldnt they plate the raw casting before the machining?
The bearings run in a race so how would the plating do anything??
Maybe they don't dissipate heat as well as a bare rotor??
Painting them so they don't rust with high-heat paint doesn't seem like it would be much different, do guys powdercoat them?
Need the thermodynamic engineers to reply I guess.
Old Feb 6, 2012 | 05:06 PM
Frank3's Avatar
They usually plate , or wash ,I've seen it both ways , the rotors after machining to keep the rotors from rusting . The coating is removed by your brake pads during break in , on the friction surfaces .
The rest of the rotor stays nicer looking awhile longer than bare or uncoated rotors .
It shouldn't affect the bearings , unless the races were installed before the plating , and that wouldn't be so good .
onofre442
Sep 10, 2013 02:24 AM
69442murph
May 30, 2012 08:05 PM
The_German
Jul 6, 2011 01:25 AM
charlierogers
Jan 25, 2011 05:19 PM
agtw31
Aug 31, 2010 02:43 PM
