71 Cutlass Timing
ASSuming a stock engine:
10° BTDC @1100 RPM for the 2bbl and the 4bbl with manual trans, 12° for the 4bbl auto,
BUT whatever works best for you is the best.
If you can advance it a few degrees and have it not ping and still start well, so much the better.
The curve on an hei is diferent, I would also recomend a setback timing light, and set your dwell @ 30, no more - no less. Then set your timing @32-34 @ what ever rpm the timing quis advancing with vacuum disconnected, usually around 3000 - 3400 rpm.
dingusboy
April 2nd, 2009 02:56 AM
