Ok why not tighten lower control arm bolts before on the ground
Old Apr 25, 2012 | 07:08 AM
J/O's Avatar
J/O
From: near border town sarnia bluewater bridge to michigan
Can someone please explain why i should have the vehicle on the ground with its weight on it before i tighten the front lower control arms and the upper nuts?
Old Apr 25, 2012 | 07:22 AM
CQR's Avatar
CQR
You will be putting your bushings under stress and cause early failure of the bushings.
Old Apr 25, 2012 | 07:29 AM
J/O's Avatar
J/O
Ok thank you CQR
Old Apr 25, 2012 | 07:30 AM
Lady72nRob71's Avatar
And the car will ride a lot higher for a while until the rubber in the bushings fail.
These must be tightened when the weight of the car is on the wheels.
Old Apr 25, 2012 | 07:48 AM
boese1978's Avatar
Is it not true that for the Poly bushings, it does not matter? Thanks
Old Apr 25, 2012 | 07:51 AM
The rule applies to poly and solid bushings as well. Entire finished weight on wheels before you tighten and torque the control arms.
Old Apr 25, 2012 | 08:20 AM
J/O's Avatar
J/O
Thank you also Rob, without having all this knowledge from all of you i could'nt have nor would i have done this work, Again thaks to all who have posted and replied to my threads.
Old Apr 25, 2012 | 08:52 AM
Run to Rund's Avatar
Put all four tires on blocks of equal height if you need more space to crawl under the car. Be sure the car can't roll off the blocks. Just jacking up one end (to do the front or the rear) won't get the right height and weight on the suspension.
Old Apr 25, 2012 | 09:23 AM
allyolds68's Avatar
Put jackstands under the rear axles. It's the easiest and safest way to work under the car with all the weight on the axles
Old Apr 25, 2012 | 09:33 AM
RAMBOW's Avatar
Ben
This is incorrect. Polybushings are not bonded to their shells the way rubber ones are, they are greased between the bushing & shell and will rotate, not bind & rip like rubber.
So poly bushings can be fully torqued to spec without the weight of the car being on them.
Old Apr 25, 2012 | 10:50 AM
Well I just learned something then... I thought they were bonded the same way. Cool!
Old Apr 25, 2012 | 12:05 PM
B964's Avatar
Besides early bushing failure the car will ride harsher and not handle as well.
Old Apr 25, 2012 | 03:09 PM
midrange's Avatar
Shaking out the cobwebs..
I think I'm glad this was question was posted.
I put a jack under the shock mount area in the lower control arm and torqued them one side at a time.
Looks like I need to redo them.
Tedd Thompson
Nov 18, 2014 09:16 AM
nolabigdawg
Oct 25, 2014 11:50 AM
JPMDaddy
Oct 20, 2013 08:21 AM
Oldssupreme
Feb 6, 2013 12:39 AM
J-(Chicago)
Feb 5, 2009 05:05 PM
