Ok why not tighten lower control arm bolts before on the ground
From: near border town sarnia bluewater bridge to michigan
Can someone please explain why i should have the vehicle on the ground with its weight on it before i tighten the front lower control arms and the upper nuts?
Thank you also Rob, without having all this knowledge from all of you i could'nt have nor would i have done this work, Again thaks to all who have posted and replied to my threads.
Put all four tires on blocks of equal height if you need more space to crawl under the car. Be sure the car can't roll off the blocks. Just jacking up one end (to do the front or the rear) won't get the right height and weight on the suspension.
So poly bushings can be fully torqued to spec without the weight of the car being on them.
Well I just learned something then... I thought they were bonded the same way. Cool!
I think I'm glad this was question was posted.
I put a jack under the shock mount area in the lower control arm and torqued them one side at a time.
Looks like I need to redo them.
Oldssupreme
Feb 6, 2013 12:39 AM
