'70 442 Power Trunk Release Parts / Pictures
Hello,
Once again calling on the "OLDS guru's...." Does anyone know what is the correct arm that comes to the power lock from the key assembly for opening the trunk with the key?
The stock rod / arm is rectangle and the power lock assembly has a triangle shape top and bottom vs the stock rectangle opening. The stock rod for emergency key opening will work but it has a very small point contact area where the triangle's meet in the center.
If someone has a factory power lock, a picture from inside the trunk showing the rod assembly (shape) would be great !
If you need pictures of what I tried to explain please let me know.
Thanks in advance.
DRXOLDS
Thanks in advance.
DRXOLDS
'70 power trunk lock
Hello,
That is the one I have. Any idea where I get the rod assembly that goes from the key lock to the power lock assembly? Is yours installed ?
Please let me know.
Thanks !
Please let me know.
Thanks !
your original should work in it. i thought in 70 they made power and non power lock rods the same? the hole is shaped differant but the rod should work i think. i will see if i can look it up in the parts book.
'70 Power Trunk
Hello,
It does work but mininum contact area. Thanks for the info. Let me know what you find! I would be curious to see if there is a different rod used manual vs power trunk for '70.
DRXOLDS
DRXOLDS
ros6872
March 7th, 2010 06:12 PM
