1969 cutlass rear 8.2 ?
Old Jan 18, 2014 | 12:57 PM
willcynn's Avatar
Trying to get info before I rip it apart,8.2 or 8.5 BOP.
Thanks Willie
Old Jan 21, 2014 | 09:52 AM
BlackGold's Avatar
Probably neither. If original and the car was not built in Canada, it's a rear end specific to Oldsmobile and only used in the '68 ('67?) through '70 model years. Tell us the casting number on the housing. The two-letter stamp in the right axle tube would also be helpful.
Old Jan 22, 2014 | 11:26 AM
Does the cover have 10 bolts or 12 bolts?
Old Jan 22, 2014 | 12:22 PM
willcynn's Avatar
10 bolts I didn't know if an O axle had a 10 bolt cover I knew they had 12.Thanks Willie
Old Jan 22, 2014 | 08:13 PM
OK, 10 bolt cover rules out the O-type that most '68-'70s came with. Check the casting number on the side of the center section as BlackGold posted.
crystal59
Dec 13, 2024 06:38 PM
Gearhead442
Feb 2, 2020 11:56 AM
monzaz
Jan 13, 2013 05:33 PM
monzaz
Oct 2, 2012 04:49 AM
mcutlass1969
Drivetrain/Differentials
Feb 12, 2008 08:59 AM
