power trunk release Rod for 66/67 Cutlass
I was able to get a complete power trunk release system setup. Attached is the size and dimensions for the ROD. I know everyone is able to get the switch and release cylinder. Maybe someone can start reproducing them.
Are you sure that connecting rod is correct for all those years and models? It seems like a lot of difference in trunk structure. Lord knows I am no expert though and could easily be wrong. If that is true, there is probably a bigger market than I thought if the same part can be used in all those cars. It very well might be profitable to reproduce the rod.
trunk lock shaft
I seen lots of these setups on ebay. without that rod. I wonder what the buyer thinks when it doesn`t work! My 65 Skylark was the same situation. I did find a shaft on ebay for a 68 big Olds. It was an inch too long so I cut it and overlapped it. Drilled and tapped 2 # 4-40 holes and put it together with machine screws. There was plenty of room and is hidden anyway. Has been working for 10 years.
John
John
trunk lock rod
You may be able to retrofit this on on ebay as I explained in the last post
John
http://www.ebay.com/itm/1966-1967-Bu...53f6eb&vxp=mtr
John
halfmoontrail
Jan 6, 2014 04:37 PM
