Tri carb question
Old Jul 27, 2013 | 07:22 PM
1arunem's Avatar
Tri carb question
Well, I got the 66 Tri carb 442 home today. Trying to identify the carbs but do not see any markings on them. Is there a stamping? They are Rochesters. What model if you will, did Olds call them?
Need info on rebuilding them. The outer two specifically.
Thanks!
Warren..
Old Jul 28, 2013 | 06:30 AM
Thanks!
Warren..
The carb types are Rochester 2GC. The identification numbers would be on a small triangular metal tag held under one of the air horn screws. These tags can get torn off or lost in a rebuild, unfortunately.
Old Jul 28, 2013 | 07:35 AM
Octania's Avatar
Isn't the "C" for Choke, making the center one a 2GC and the others 2G?
Minor detail, to be sure.
The carb numbers [which were on tags] should be
7026055
7026056
7026057
Which will get you the right kits. PN 1134 at Fusick's for the kits. I cannot find the tag vendor right now but it can't be that tough.
Old Jul 28, 2013 | 07:43 AM
Toyaholic's Avatar
It's a sickness!
Correct. The center carb is a 2GC and the end carbs are 2G's.
Found this multi-part video for rebuilding.
Stacy David did a show a couple years ago about the tri-power as well.
Hope this helps.
Old Jul 28, 2013 | 09:44 AM
1arunem's Avatar
Awesome! Thanks guys!
Old Jul 28, 2013 | 09:48 AM
Good point, thanks.
Old Aug 1, 2013 | 05:58 PM
BILL DEMMER's Avatar
Just the facts...
actually, the "c" (or "v") specifies the type of choke, in the case of a "c" it is the self-contained choke integral to the carb. body. now if we were talking about a divorced choke coil equipped carb, the letter would be a "v".
bill
Old Aug 1, 2013 | 09:17 PM
mid60soldsfan's Avatar
For tri-carb tags, recommend contacting Mike Siedlik via http://www.thegoodoldsdays.com/. He makes high-quality reproduction units at a reasonable price. Good luck.
KB
Old Aug 1, 2013 | 11:36 PM
RAMBOW's Avatar
Ben
for the carb rebuild stuff... contact Mike Wasson with www.pontiactripower.com
He has all the hard to find specific parts for the tripower 2bbl carbs... new throttle shafts, choke parts... basic rebuild kits... etc etc. Even thought they specialize in the pontiac stuff, he knows the Olds stuff too.
Super nice & helpful guy also.
Old Aug 2, 2013 | 07:06 AM
Toyaholic's Avatar
It's a sickness!
Before and after
Thought I would throw in before and after pictures of the tri-power.
I know.. I know... it's not stock.
Old Aug 2, 2013 | 07:13 AM
Toyaholic's Avatar
It's a sickness!
What distributor is everyone using with the tri-power?
Currently using a multi-spark summit box and the billet street / strip distributor. Would like to get rid of the box to make it more period correct. Some where I saw a GM Delco sticker that would cover the Summit label, just can't find it now. Maybe I can hide the box and switch to a round coil.
Any ideas?
Old Aug 10, 2013 | 06:40 AM
Toyaholic's Avatar
It's a sickness!
No help on the distributor?
Old Aug 10, 2013 | 07:49 AM
TripDeuces's Avatar
I don't understand why adapter plates were used on the carbs in the before pic? Those are for bolting a Holley 2bbl on a 2G base or vice versa.
Your set up looks nice
Old Aug 10, 2013 | 07:56 AM
Toyaholic's Avatar
It's a sickness!
Think the adaptor plates will cause issues? Same plates are on the rebuild, just cut off the ears. Having an idle issue. Won't idle below 1100 without stalling.
Here's a link to the idle issue thread. https://classicoldsmobile.com/forums...tml#post578312
Old Aug 10, 2013 | 08:00 AM
TripDeuces's Avatar
You're not using them now as far as I can see in your pics. I'm just wondering why they were used in the first place.
Here's an example of what I'm talking about. Holley to Rochester base
Old Aug 10, 2013 | 08:27 PM
1arunem's Avatar
Finished rebuilding them today. I got the rebuild kit from John at pontiac tri carb.com as mentioned.. Very helpful and the car seems to be running well.
The previous owner had the front and rear carbs blocked off and said they kept flooding the engine. I found the floats on the front and rear carbs way off (adjustment wise).
Old Sep 12, 2013 | 06:59 PM
2Olds4U's Avatar
Majored in rear tire demo
I know it's an older post, Trip, but maybe the adapters are small base to large base? Hard to tell by the pics.
Old Sep 13, 2013 | 03:36 AM
Toyaholic's Avatar
It's a sickness!
The plates are still on there. The ears were cut off and powdercoated to match the carbs.
bocoogto
Aug 13, 2020 05:30 PM
NTMD8TR
Sep 17, 2014 10:27 AM
RandyS
Oct 4, 2012 12:36 PM
bocoogto
Mar 29, 2008 10:00 AM
bocoogto
Mar 27, 2008 05:49 PM
