Flarestat interchange
Old Nov 25, 2013 | 03:32 PM
deaddds's Avatar
Does anyone know if a Pontiac flarestat Grp #2.575 Part #984598 works with Oldsmobile? Thanks
Old Nov 25, 2013 | 03:51 PM
Are you taking about one of these?
http://www.ebay.com/itm/NOS-1966-66-...-/200991318407
I'm sure you can make it work.
Old Nov 25, 2013 | 03:52 PM
Paladin31's Avatar
Check out this site, think its what you need...
http://parts-9.obsoletepartfinder.co..._984650-1.html
Best Good luck
Old Nov 25, 2013 | 04:07 PM
That part number is not in the Olds Parts Manual.
As Eric says, most of this stuff was functionally similar, if not identical, and the different part numbers often represent cosmetic differences (such as different dashboard *****).
Good luck!
Old Nov 25, 2013 | 04:23 PM
deaddds's Avatar
That's what I'm thinking, the books I have don't show it as interchanging but would think it could. There is a # for 66 olds but it doesn't show a corresponding Buick, Pontiac, Cadillac use.
Old Nov 25, 2013 | 04:43 PM
It's an aftermarket dealer installed item, the flarestat corp made different ones for all makes. If it's for an A body it should work.
Old Nov 26, 2013 | 05:11 AM
rocketraider's Avatar
Oldsdruid
If it's carrying a GM part number the difference between the marques will be the plug at the turn signal switch end. As an example I have one on my 64 Starfire that listed for a 1966 Cadillac. The t/s switch plug is the same, it's the earlier triangular plug at bottom of steering column.
Other applications may use the later crescent type plug. Sometimes the GM parts package will include a jumper harness to mate different t/s wiring.
A generic Flarestat will require a good understanding of the car's turn signal wiring but they're not difficult to install.
BeenThere
Feb 10, 2013 07:03 AM
oldsmobilia
Mar 20, 2009 07:38 AM
oldsmobilia
Dec 27, 2008 09:43 AM
<Ryan B>
Dec 18, 2005 07:02 PM
Jake Lydey
May 16, 2005 06:52 AM
