Tune up for a 1956...
Old Feb 13, 2009 | 10:14 PM
Brizio's Avatar
Sorry guys if I make a lot of questions, but I'm new and I need to learn.
I would like to make a tune (spark plugs, wire, oil and filters) up at mine 1965 Super88, which spark plugs are better for it?
And which kind of oil???
I should search it in a normal auto parts, or better search it online?
Thanks!!!
Old Feb 14, 2009 | 01:05 PM
Brizio's Avatar
WoW!!! You gave me a lot of good informations!!! Thank you!!!
Old Feb 14, 2009 | 01:38 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'd put in shell rotella-T oil.
Old Feb 14, 2009 | 03:51 PM
Bluevista's Avatar
Registered
I would get rid of the points and put in a Pertronix or Mallory type points conversion unit. They are simple to install and you never have to worry about points and their inherent problems again. There are several type out there. I think the Pertronix is a magnetic trigger and the Mallory has an optical trigger. I do the conversion with every car that I plan on keeping. My Mallory Unilite conversion has been going for 15 years steady, put one in the Vista too. Shop around for prices if you do go that route.
http://www.pertronix.com/prod/ig/ignitor/default.aspx
http://www.malloryperformance.com/Pr...minselection=0
Old Feb 14, 2009 | 04:51 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Just a note on oil filters. I think NAPA has one called NAPA Gold which is top of the line. Years ago at an part store I saw a display with a Fram filter and a Wix filter cut open. The Wix had about twice the filter service of the Fram. I had used Fram for years and have never used another one. Wix is a really good filter. That was probably 15 years ago and I know there are a lot of other good filters available. Bluevista gave some good advice on the Pertronix ignition. It will be money well spent.
Old Feb 15, 2009 | 05:15 AM
csstrux's Avatar
I run rotella t 15w40 in everything I own anymore.
Old Feb 15, 2009 | 08:09 AM
Brizio's Avatar
About the oil filter, the previous owner gave to me 2 Napa Gold.
Old Feb 15, 2009 | 09:37 AM
citcapp's Avatar
I run the Rotella as well. great break in oil too
Old Feb 15, 2009 | 11:52 AM
csstrux's Avatar
NAPA filters are made by wix. they are good filters. The gold line is NAPAs premium filter, so you are good to go. I use them on my truck
onetogofast
Jun 2, 2009 05:02 AM
csouth
May 28, 2009 04:46 AM
gypsy66delta
Aug 19, 2008 12:54 PM
southcarolina803
Jul 8, 2008 07:37 PM
RussTad
Sep 14, 2006 04:09 PM
