Flywheel question
Old Apr 19, 2009 | 03:51 PM
oldjunk's Avatar
Flywheel question
Hi!
Will a 350 flywheel work on a 455?
Old Apr 19, 2009 | 04:17 PM
2blu442's Avatar
Yes! As long as you have a crankshaft drilled for the manual transmission input shaft. There have been several threads discussing the crank situation, do a search on that topic if your not sure about it. John
Old Apr 19, 2009 | 04:39 PM
oldjunk's Avatar
Thank you for the help.
Old Apr 20, 2009 | 11:06 AM
Let me clarify just a little. Yes, any 1968-1990 Olds flexplate or flywheel will bolt up to any Olds engine in that period. Is the original question about a true manual trans flywheel, in which case the statement above applies, or about an automatic trans flexplate (which people frequently call a "flywheel" also), in which case the drilling can be ignored.
sixtyfour
Jun 27, 2013 09:00 AM
2oldsguy
Jan 3, 2013 02:04 PM
RandyS
Jul 13, 2012 11:22 PM
cbold68
Jan 15, 2012 06:22 PM
trevordavis
Dec 14, 2011 12:39 PM
