Flywheel question
Old Jan 3, 2013 | 04:51 AM
2oldsguy's Avatar
Flywheel question
I have a 70 455 W-30 4 spd. and when I pulled the inspection cover I noticed the flywheel had writen on it "73 Cutlass 350".
Is the small block and big block flywheels the same.
I am having a slight engine vibration ever since I purchased the car.
Joe
Old Jan 3, 2013 | 05:27 AM
2blu442's Avatar
Hi Joe
The small block and big block flywheels are the same, so that shouldn't be the problem. Sorry but I don't have a good suggestion of what to look at next.
John
Old Jan 3, 2013 | 07:32 AM
Run to Rund's Avatar
Check your harmonic balancer. If the ring is slipping, you can get a vibration. Beyond that, the clutch or even the flywheel may need to be balanced with the crank, etc. That would involve disassembling the engine. Also make sure the vibration isn't just a bad spark plug or wire.
Old Jan 3, 2013 | 02:04 PM
2oldsguy's Avatar
Thanks for you replys. I was told by the previous owner that it spun a bearing and he changed one rod and crank. So I assume I have an internal balance problem.
That is a project for a later date.
Joe
sixtyfour
Jun 27, 2013 09:00 AM
RandyS
Jul 13, 2012 11:22 PM
cbold68
Jan 15, 2012 06:22 PM
trevordavis
Dec 14, 2011 12:39 PM
oldjunk
Apr 20, 2009 11:06 AM
