66 442 Flywheel Question
Old Jul 9, 2012 | 04:21 PM
RandyS's Avatar
I know that the 66 442 originaly came with a flywheel that would accomodate an 11" clutch & PP. I'm just wondering if all Olds flywheels of that genre were 11", or were there other diameters used?
Old Jul 9, 2012 | 05:14 PM
aliensatemybuick's Avatar
"me somebody" site member
I am aware of early (64-67) ones that came drilled for both 10.5" and 11" clutches, and others that were drilled for 10.5" only (per a friend with a 4 speed '65 Jetstar I). Not sure if there were 11" only versions from the factory or not.
Old Jul 9, 2012 | 05:24 PM
jensenracing77's Avatar
i have an original that was removed from a 66 442 and it is drilled for both.
Old Jul 9, 2012 | 07:44 PM
Run to Rund's Avatar
AFAIK, all Olds wheels were drilled for 10.5" and 11" diaphragm or Borg and Beck pressure plates (not Long style) from 1965-up.
Old Jul 9, 2012 | 07:54 PM
Wmachines/Kurt mentions the 10.5 inch flywheel in post 8 in this thread:
https://classicoldsmobile.com/forums...size-cars.html
He doess say its the only one he'd ever seen drilled only for the smaller clutch.
Old Jul 9, 2012 | 08:43 PM
RandyS's Avatar
That was what I was looking to find out!
Thanks!
Old Jul 13, 2012 | 11:22 PM
65B01Delta's Avatar
I have a 1965 Delta 3 on the tree (425 ci ) & I was told by the previous owner that it has a 11 inch clutch. Also it was a Police Chief's car back in 65..... The clutch is weak, so when I change it out soon, I will post pictures. Still looking for a build sheet to verify it's it is in fact a B01.....
sixtyfour
Jun 27, 2013 09:00 AM
2oldsguy
Jan 3, 2013 02:04 PM
cbold68
Jan 15, 2012 06:22 PM
trevordavis
Dec 14, 2011 12:39 PM
oldjunk
Apr 20, 2009 11:06 AM
