Flywheel Question
Old Dec 14, 2011 | 11:18 AM
trevordavis's Avatar
Flywheel Question
Does anyone know off the top of their head the tooth count on a OE Flywheel for a 455 motor? I just recently stripped mine and trying to pinpoint what my next step should be. Your insight is appreciated!
Sincerely,
Trevor.
Old Dec 14, 2011 | 11:43 AM
Oldsmaniac's Avatar
166
Old Dec 14, 2011 | 11:46 AM
Roger that, thank you.
Old Dec 14, 2011 | 12:06 PM
Run to Rund's Avatar
Dorman flywheel ring gear
http://www.summitracing.com/parts/RN...n/?prefilter=1
Old Dec 14, 2011 | 12:12 PM
So if the flywheels simply just stripped I can just get away with purchasing a ring gear? Clearly flywheels aren't my strong point.
Old Dec 14, 2011 | 12:19 PM
Oldsmaniac's Avatar
It is common to just replace the ring gear. Also at times they can be turned around by a machine shop to get fresh teeth toward the starter if none are missing or very bad..
Old Dec 14, 2011 | 12:26 PM
I see, well if this is the case, it would probably be much more cost effective! Which of course, I'm always a fan of!!
Old Dec 14, 2011 | 12:39 PM
I went ahead and just now ordered to ring gear! Appreciate the swift help oldsmaniac, I'll keep posted on what ends up happening!
sixtyfour
Jun 27, 2013 09:00 AM
2oldsguy
Jan 3, 2013 02:04 PM
RandyS
Jul 13, 2012 11:22 PM
cbold68
Jan 15, 2012 06:22 PM
oldjunk
Apr 20, 2009 11:06 AM
