71 455 Carb Question
Old Mar 13, 2010 | 06:19 PM
sklbndt's Avatar
Hey guys....need some help. I've got a 68 cutlass with a 71 455.
First, what manual is the best to get with this setup? I already have all the 68 manuals but with the 71 motor should I get the 71 chassis or assembly manual? Or maybe both? Or is there something else you would recommend.
Second, I just got my hands on a 7041251 carb to replace the 73 Pontiac carb that is currently on it and I have a question on the new carb. On the back just below the compensator cover there is a hole in the base plate (bottom center of carb in pic). The one on the Pontiac carb was plugged. Should this be plugged and if not what is it for?
Thanks in advance!!
Old Dec 29, 2012 | 08:34 PM
Dshelvy's Avatar
The bottom section is off a newer Carb its for a brake booster
Old Dec 29, 2012 | 10:33 PM
BILL DEMMER's Avatar
Just the facts...
that threaded hole in the throttle body is a manifold vacuum connection. it can be used for the brake booster, or other devices requiring manifold vacuum. pontiacs tended to use a vacuum tree(of various configurations) which was threaded in to that opening. if you don't need it, plug it with a pipe plug using teflon tape or a sealer applied to the threads.
it wouldn't hurt to have a '71 csm. do you NEED one-probably not.
bill
Old Dec 30, 2012 | 04:49 PM
Dshelvy's Avatar
When i bought my 350 it had this carb on it by any chance bill do you know cfm it is
Old Dec 31, 2012 | 10:05 AM
Just the facts...
750 cfm
bill
Old Jan 1, 2013 | 07:01 PM
sklbndt's Avatar
Wow....Can't believe it took 2 1/2 years to get an answer to this! Appreciate the feedback but my carb issues have long been resolved. I ended up just plugging the hole.
Old Jan 4, 2013 | 07:38 PM
Dshelvy's Avatar
LOL better late than never... i was having problems with my Carb which is the same as Yours
HKanada182
Oct 20, 2014 07:48 PM
Don R
Oct 6, 2012 09:47 AM
RandyS
Oct 4, 2012 12:36 PM
sethj78
May 2, 2012 02:06 PM
Phil Glass
Mar 10, 2012 04:28 PM
